12/14/2011 5:59 PM | |
Posts: 6 Rating: (0) |
Thanks for the quick reply. I am using professional along with the IPC runtime. I have the latest updates as well. |
12/16/2011 12:44 PM | |
Posts: 3037 Rating: (192)
Hello, I have not found this settings of WinCC flexible in WinCC Professional either. You can use WinCC Professional with Simatic Logon. You have with Simatic Logon the Windows Logon system. See this in the chapter 5.4.3 Logging on with Simatic Logon. SIMATIC Logon Tweety |
12/16/2011 5:16 PM | |
Thanks Tweety. I believe with previous versions, there was an additional charge for this. Do you know if this is still the case with TIA? |
12/17/2011 7:05 PM | |
Joined: 8/31/2010 Last visit: 1/24/2025 Posts: 1523 Rating: (230) |
Hello RobbyR, SIMATIC Logon is one of the Runtime option for WinCC v11. (Check here - Delivery release SIMATIC WinCC V11) |
Like it? Rate it! |
