3/31/2009 7:59 AM | |
Joined: 11/15/2006 Last visit: 5/7/2021 Posts: 1319 Rating: (171) |
The PC Adapter USB needs power from the CPU MPI port. I guess the STAHL CPU doesn't have it. The CP5511 / 5512 doesn't need it. Either you build yourself any kind of power module for the adapter. Here a link to an FAQ about this topic: http://support.automation.siemens.com/WW/view/en/20279422(here you find everything you need) Edit: Just seen: SIMATIC S7, PLUG-IN POWER SUPPLY UNIT SET FOR EXTERNAL POWER SUPPLY OF THE PC ADAPTER USB 00V-240V AC/ 24V DC http://support.automation.siemens.com/WW/view/en/27230249 |
