6/8/2012 4:01 PM | |
Joined: 3/16/2012 Last visit: 5/1/2024 Posts: 34 Rating:
Dear Experts; I need your helps.
6/22/2012 10:25 AM | |
Joined: 3/14/2008 Last visit: 7/25/2024 Posts: 2079 Rating:
Take my advice: Use PCS7 environment only.. You can make your custom blocks by programming in SCL,FDB, STL, but I would suggest to use CFC charts for main programming... I started up an old plant with seperate S7300 modules with their own programs and sending data to and from S7400. (PCS7 4.0). I had a lot of problems with errors and a lot of time figuring out which data to send on profibus. I removed all S7300 and replaced by ET200M. I converted the S7 programs to CFC and everything runs smoothly. |
