1/18/2010 12:14 PM | |
Joined: 3/3/2008 Last visit: 10/5/2023 Posts: 333 Rating: (52) |
hi normally the beep sound indicates the ram section is faulty, try to replace the PCU50 regards ram |
11/22/2012 8:02 AM | |
Posts: 6 Rating: (0) |
Hello Have You succed to find the problem? I am in the same situation.
11/22/2012 8:32 AM | |
Posts: 91 Rating: (1) |
Hello, try to connect an external monitor to Dvi-i interface (x302). check.
11/22/2012 1:50 PM | |
Thank You for fast reply. I have already tryed all the thing thatSammyMahsay in the first post but nothing...still black screen. I also extract the procesor from the slot and put it back. I was thinking to heat the motherboard with a hot air station maybe this will work. |
11/22/2012 1:55 PM | |
Posts: 2964 Rating: (484)
Hello.... This could be the problem with the 24v dc powersupply inside too.... Regards, Prakash |
