6/3/2016 6:22 PM | |
Joined: 6/3/2014 Last visit: 2/1/2021 Posts: 660 Rating:
Hello borata, you have three options:
About the configuration: If you use the PDF viewer you just need to add the system function "StartProgram" on your button and configure it as described in the FAQ. If you use the PDF control you can dynamize the visibility of the control. Set/Toggle the tag you use for the visibility when pressing your button. |
6/6/2016 10:05 AM | |
Joined: 5/27/2015 Last visit: 3/8/2022 Posts: 93 Rating:
Thank you !!!!! |
