4/7/2016 12:11 AM | |
Joined: 9/27/2006 Last visit: 9/22/2023 Posts: 12152 Rating:
Hello Mpaulissen:
A S7 DSGW is a PDM object named a Data Record Gateway, that routes data from the plant bus (Ethernet) to field buses (PROFIBUS); routing takes place via TAG licenses. S7 DSGW existed in versions prior to PDM v9, but a separate license was required for PDM Routing.
Integrating an S7 DSGW gateway in PDM v.9 is described in section 7.3.1.8 of the following manual.
SIMATIC Process Control System PCS 7 Help for SIMATIC PDM (V9.0) https://support.industry.siemens.com/cs/ww/en/view/109482406 Hope this helps, Daniel Chartier |
