11/7/2014 7:49 AM | |
Joined: 10/11/2006 Last visit: 1/27/2023 Posts: 5404 Rating:
Hello DavidBrown, with CU320 and even CU320-2, you cannot run 4 motors in vector with 250µs. For CU320 only two vectoraxis are possible in 250µs and for CU320-2 3 vector axis are possible with 250µs. You can check this in advance using Sizer, butthere are onlyCU320-2 isavailable in the actual versions. Depending on your application and motor types you may use servo control to get faster controller cycles. |
With best regards, |
