8/21/2013 12:12 PM | |
Joined: 12/4/2009 Last visit: 3/19/2025 Posts: 453 Rating:
Dh_1811, L and T functions work with accumulators, which in the other words brings limited amount of handled data. Unless you want tu use a loop with pointers and address registers, BLKMOV (UBLKMOV) is the only method of mass data transfer. Hope this helps. Regards.
If this post actually helped, you may consider using the Rate button above. |
