4/25/2008 2:44 AM | |
Posts: 191 Rating:
Hi!! the reference is for using the value ofan alredy programmed analog block as the parameter of this block... and yes, you canuse the same value in different blocks using the "reference", just place the value you want as SP in the aoutput of an analog block and use this block as reference in the PI.. hope this helps!! ROSA AttachmentPI.zip (361 Downloads) |
