4/14/2009 10:59 AM | |
Posts: 14 Rating:
hi, i am using wincc v6.2, and i am opening one screen in one picture window using a button. and there is one indication light on this button, which turns green when screen opens, script for this led is already in the button. but when i close the picture window that led remains green. i have used window property "can be closed" to close the window. i have tried this trick from your forum but not able to solve it. /tf/WW/en/Posts/17468 i want to turn that led to again to red when window closes. please help........ |
4/15/2009 8:31 PM | |
Joined: 3/18/2009 Last visit: 2/8/2022 Posts: 306 Rating:
Hi samra, There are many ways as already mentioned in the thread that you found. Adding to them, you can also try this
To make things clear, I have attached two .pdl files. May be it explains better. Just copy them in your project, create an internal tag "Display" (binary) and try the buttons. hope it helps. AttachmentPicWindowSts.zip (37 Downloads) |
