12/10/2018 2:47 PM | |
Joined: 3/26/2015 Last visit: 9/16/2021 Posts: 20 Rating:
Hello! Perhaps your Ti is too high! Please check your output limits: If you are using PID_Compact >= V2.3 check static parameter "PIDCtrl.PIDInit". It has to be FALSE! Also you can change the "IntegralResetMode". But this is only for the change from "Inactive" to "Automatic": If you are controlling a value, the "PID_3Step" would be better, because it is especially for valves or actuators with integral response: |
12/11/2018 3:03 PM | |
Dear Yoav, are you using "OverwriteInitialOutputValue"? |
