11/26/2014 1:37 PM | |
Posts: 12 Rating:
Thanks but what parameter should I give? IS it necessary to give parameter manually? |
11/26/2014 1:41 PM | |
Posts: 12 Rating:
and shoul I not use PID_Compact or PID_3step ? |
11/26/2014 1:58 PM | |
Posts: 12 Rating:
Thanks for your support, I think I should learn about cont_c first.. |
11/26/2014 4:57 PM | |
Posts: 12 Rating:
How can I check my program with out connecting actual hardware ? Is there any example ?
11/26/2014 7:45 PM | |
Joined: 1/28/2009 Last visit: 11/18/2023 Posts: 6822 Rating:
Hello again, There are some samples for STEP 7 in which you can see how to call and use CONT_C in deifferent scenarios.You can start from my favorite and check carefully all samples: Different ways to call PID controller' FBs Plus check all clustered discussions here: HD_PID Control Package - FB41 Samples in case of development of your program, share all PID section in .pdf format for more analysis.This is crucial because it gives you a chance to receive comments from a wide range of users. Best regards, hdhosseini |
Last edited by: hdhosseini at: 11/26/2014 8:09 PMLast edited by: hdhosseini at: 11/26/2014 7:47 PM |
11/26/2014 11:11 PM | |
Posts: 12 Rating:
I am using Tia Portal. Do you have some sample example in that case ? |
