2/9/2022 3:48 PM | |
hi Voulez, at first: this is not STL, It is SCL. second: we can not see what you are meaning. Make a screenshot in online-view and tell us exactly what you are expecting and what is not like you expected. third: consider that your PLC is in STOP. Scaling can be done with the SCALE_X and UNSCALE_X functions that can be found in basic instructions->conversion instructions. There is also a FAQ about this funcitons: For an S7-1200/S7-1500 controller in STEP 7 (TIA Portal), how do you scale integer values in real numbers and vice versa for analog inputs and outputs? TIA help also explains hot it works. hope this helps, regards, |
2/9/2022 9:48 PM | |
Joined: 2/8/2022 Last visit: 12/9/2022 Posts: 14 Rating:
So this is my graph with my PID control |
2/17/2022 9:31 AM | |
I got it. Thank you very much !! |
