4/29/2023 1:16 AM | |
Joined: 3/23/2023 Last visit: 4/29/2023 Posts: 1 Rating:
I am running usecase 2 (pendulum) control on a simulated controller (PLC Sim Advanced) via OPCUA, the PID is not responding. I have assessed the mode of operation, the server-client communication, it seems normal. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 05/02/2023 09:03:12New subject after splitting |
5/18/2023 2:36 PM | |
Joined: 7/19/2022 Last visit: 5/22/2023 Posts: 160 Rating:
Hello AutoGen_6864864, To simulate PID I think that you need the following library: Closed-Loop Control of Simulated Controlled Systems in the S7-1500 with PID_Compact V2 In other case you can´t simulate PIDs |
