9/3/2019 11:23 AM | |
Joined: 5/17/2018 Last visit: 12/20/2022 Posts: 25 Rating:
Hi, RampFunction block seemed work well , it made interpolation correctly but when I sent Temperature from every time to PID it is variable and it didnt tuner PID well. Does it work based on Lagrange Interpolation? Don't it? Following your advice to achieve my challenge , i downloaded LGF from siemens website. I have got some problems adding global library to the SW TIA Portal v15. I download rar file for the version v15.1 called "TIA Portal V15.1 Library LGF V4.0.4 (12,4 MB)" from this link: https://support.industry.siemens.com/cs/ww/en/view/109479728 After downloading , all files were extracted at desktop then i am going to label "Libraries" -> "Global Library" then click "Open Library" .Then select folder route where files were extracted, but here problem comes... there is not any file with the extension .al15 (Library Tia portal) . The extension of the main file is .al15_1 which is impossible to open it. Any suggestion? Thanks, |
Last edited by: crisdonate at: 09/03/2019 11:25:14Last edited by: crisdonate at: 09/03/2019 11:25:55Last edited by: Jen_Moderator at: 09/03/2019 13:05:26Optimized link. |
