1/29/2013 11:19 AM | |
Joined: 4/22/2010 Last visit: 5/3/2024 Posts: 5697 Rating: (715)
Hello, You cave connected the Pnoz with 2 channel function, the 2 chanels should brake at same time or fault is detected. You can connect the Pnoz 1 channel function(with barriers in series), but then you will lose safety check functions. I have attached the installation instructions. For more questions or help i suggest you go to your local Pilz website to find a contact, they are verry helpfull. Regards, Marcjan AttachmentPNOZ_s4_Operating_Manual_21396-3FR-11.pdf (456 Downloads) |
Problem solved? |
