3/21/2012 12:24 AM | |
Joined: 10/7/2005 Last visit: 5/29/2023 Posts: 2965 Rating:
Hello Eng.ahm you may get away with simply installing a so calledequipotential bonding cabletogether with the Profibus cable, butthe best advise I can give you is to make sure you have a proper earth and grounding in place across your whole Plant. You'll find some good general avise on the importance of a proper shielding and grounding at Cherry Clough Consultants, specifcially their research papercalled The Benefits of Applying IEC 61000-5-2 to Cable Shield Bonding and Earthing. For anything Profibus related, go to www.profibus.comand grab especially copies of the Guideline__Assembling_8022_v106_May06.pdf (contains also the info on the equipotential bonding cable) and Guideline_Commissioning_8032_v102_Nov06.pdf which can bedownloaded for freefromHERE. I hoep this helps |
Cheers |
