9/21/2008 1:59 PM | |
Posts: 4 Rating:
i jus got a pg710 plus and a 101u s5 plc. But i wondering how do i write the program on the pg orcan i get a windows based program for the plc? |
9/21/2008 3:52 PM | |
Posts: 1064 Rating:
You need step 5 on the pg to write to the s5 plc along with the cable |
9/21/2008 6:34 PM | |
Joined: 11/30/2006 Last visit: 3/16/2021 Posts: 118 Rating:
Hi you can try this Demo version of S5 http://www.classicautomation.com/STEP-5-Alternative.aspx http://www.ttintl.com/english/s5w.html Alsocheck this Manual for Programming of S5 http://support.automation.siemens.com/WW/view/en/1175533 |
9/22/2008 2:30 PM | |
Posts: 487 Rating:
Siemens S5 PLC does not use RS232, it uses TTY signals for communication. With standard PCs, you need a RS232 to TTY converter to communicate with PLC. But PGs from Siemens has TTY converter inbuit. Normally on PG7XX, COM1 is a DB25 pin connector, this can be used to connect to PLC. You also get a cable with PG, but if you to make your own cable, forconnection details check the link below. http://support.automation.siemens.com/WW/view/en/217863 |
9/22/2008 8:39 PM | |
Posts: 4 Rating:
thank you manual really help. Now i got the plc connected to teh pg and fully working. thanks again |
