10/20/2008 1:20 PM | |
Posts: 13 Rating:
Hi I've attached screenshots hoop you can do anything with it. I still have the problem. The physical network is connectedproperly I can ping every node. On the cpu it says version 2.3.4 and I'm using 2.3 and tried 2.6 but the problem ain't solved yet. I hoop you can help or else I wouldn't know what to do. greetings anjenny Attachmentspectation VDX.zip (123 Downloads) |
