6/18/2015 9:06 AM | |
Joined: 8/3/2009 Last visit: 1/24/2025 Posts: 14651 Rating: (1824) |
Hello Paul1970 In this FAQ you can find the Information how you can change a screen out of the PLC: http://support.automation.siemens.com/WW/view/en/93909293 When you want to open the screen when the Signal goes to low then you have to check this in the PLC and use the "Controller Job" area pointer. Have a nice Day Bye Murof ------------------- When this information helps, you could use the Rate Button |
