2/13/2018 6:56 AM | |
Joined: 11/6/2017 Last visit: 1/16/2023 Posts: 27 Rating:
Hi Huggy! [snip] Thanks Regards, Bilal ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 2/13/2018 8:46:45 AMNew subject after splitting. Division of questions into separate topics. |
2/13/2018 2:50 PM | |
Joined: 10/16/2007 Last visit: 2/3/2023 Posts: 570 Rating:
Did you connect the power supply correctly? What type of input-cards do you use? Regards |
2/13/2018 4:34 PM | |
Screenshots of your project tree might help. Some samples of online monitored logic showing input states not changing in the real world, but the plc is not seeing those changes.
science guy |
2/21/2018 2:22 PM | |
Hi, Power supply's seems to be working. Voltages across switches and sensor have been measured no issue found. I have taken some pictures in which you can see OB1, Pump and Limit switch networks. Please find the pictures in attachment Thanks Regards Bilal AttachmentProject Networks.zip (48 Downloads) |
