8/21/2012 3:35 AM | |
Joined: 10/7/2005 Last visit: 5/30/2023 Posts: 2965 Rating:
Hello ABD2008 pelase check if you followed the correct startup procedure as per chapter 6 of the SIMATIC S5-135U/155U System Manual. Should that not help you, pelase check the CPU's I-Stackand B-Stack and provide the info here if you need more help. |
Cheers |
