10/21/2013 9:40 AM | |
Posts: 220 Rating: (11) |
Hi RaviS, please lookhereto check if you can use the Hardware for PCS 7 V8.0 SP1. If you use an other version look in the same manual for your PCS 7 version. How you can use a S7-300 CPU with S7-400 CPU in PCS 7 look toLinkthat SilentBob have postet above. |
10/23/2013 11:21 AM | |
Joined: 4/24/2009 Last visit: 8/20/2024 Posts: 2682 Rating: (135) |
Thread closed, because question is already published in the following thread Can PLC S7-315-2PN/DP be programmed by PCS7? Best regards O_Moderator |
