2/21/2018 12:24 PM | |
Hello Iceman in this Link you can see examples how to use a PLC Datatype directly in the HMI. https://support.industry.siemens.com/cs/ww/en/view/68014632 This works since TIA V13 SP1. If you have an older version or you use a Classic PLC like S7300/400 then you have to use non optimized Blocks and work with HMI UDTs. Bye Murof |
