3/23/2007 7:40 PM | |
Posts: 8 Rating:
Can OPC Scout be used to read/write data to PLCSIM from an OPC Client? I want to be able to use PLCSIM with Wonderware Intouch for testing. |
8/11/2009 6:32 AM | |
Posts: 261 Rating:
Hi Meritor Can you give us any example S7 program? What will be setting for In Touch System management console? With regards ddg |
8/11/2009 7:20 AM | |
Joined: 3/21/2006 Last visit: 3/2/2023 Posts: 10221 Rating:
Hello, S7 program can be all S7 progect. And there just you'll prepare necessaries data to be show on SCADA. Take a look at How do you configure communication between the WinCC flexible Runtime and WinLC via SOFTBUS on a PC? But instead of WinCC FlexRT you should put OPC Server. About settings in Intouch- OPCLink (you'll connect this server with SimaticNet OPC Server) look at SCADA Setting - InTouch (OPCLink)Hope this will helps.Best regards, Hristo Mihalev |
10/10/2009 9:29 AM | |
Posts: 45 Rating:
Hi everybody, you can try PLCSIM OPC Server |
