9/25/2009 7:20 AM | |
Joined: 3/21/2006 Last visit: 11/1/2024 Posts: 10229 Rating: (1181) |
Hello MemoGG, Look at follow FAQ: How do you use S7-PLCSIM with SIMATIC PCS 7? (Entry ID:16522013). Hope it will answer of your questions. Regards, Hristo Mihalev |
9/25/2009 9:28 AM | |
Joined: 4/5/2006 Last visit: 10/10/2024 Posts: 917 Rating: (63) |
Hi MemoGG , yes, you cam use PLCSIM and REAL PLC in same time, but: 1) PLCSIM works locally ONLY: means you need PLCSSIM and WinCC Server on same PC 2) PLCSIM works with MPI connection only up to v5.3; it works with Ethernet connection from v5.4 3) it's no possible connect WinCC to PLCSSIM installed on different station You can compile OS normally for real PLCs and change connection to ethernet for PLCSIM Regards |
