8/8/2011 5:55 PM | |
Joined: 1/28/2009 Last visit: 4/1/2024 Posts: 6836 Rating: (1359) |
Why don't you use SFC20? What should you watch out for when you use the SFC20 "BLKMOV", SFC81 "UBLKMOV" or SFC21 "FILL" blocks? [code] CALL "BLKMOV" SRCBLK :=P#DB1.DBX0.0 BYTE 10 RET_VAL:=#RET DSTBLK :=P#DB2.DBX0.0 BYTE 10[/code] Best regards AttachmentSFC20.pdf (555 Downloads) |
Last edited by: hdhosseini at: 8/8/2011 6:18 PMLast edited by: hdhosseini at: 8/8/2011 5:59 PM |
8/9/2011 1:02 PM | |
Posts: 23 Rating: (0) |
Hello, hdhosseini, the problem is not with SFC20, I just want to realize transfer data to an out parameter with ANY type in a FC, just like my attached picture. |
8/9/2011 3:27 PM | |
Why not checking FC47 (Copy data area-ANY pointer) which is a sample from "Automating with STEP 7 in STL and SCL-Hans Berger". The examples are free of charge and can be dowloaded from the following links:
Best regards AttachmentFC47.pdf (422 Downloads) |
8/10/2011 5:47 PM | |
AttachmentFC47.zip (268 Downloads) |
Last edited by: hdhosseini at: 8/11/2011 4:34 AMLast edited by: hdhosseini at: 8/10/2011 5:58 PMLast edited by: hdhosseini at: 8/21/2018 2:31:45 PM |
8/11/2011 7:37 AM | |
Ok, thank you. Now I see. |
7/23/2015 10:23 AM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4774 Rating: (123) |
