6/2/2010 11:30 AM | |
Joined: 3/21/2006 Last visit: 10/7/2024 Posts: 10229 Rating: (1181)
Hello, In S7 CPU you don't need any special application to communicate with MP277. For example How do you configure a connection between WinCC flexible Runtime (PC or Panel) and a SIMATIC S7-300 / S7-400 via Industrial Ethernet? . The point is you should build all the logic regards panel again in S7 CPU. I don't think existing application to be so helpful. Best regards, Hristo Mihalev |
6/10/2010 4:47 AM | |
Posts: 48 Rating: (0) |
Thanks UMENCHO so much! |
