9/20/2016 6:20 AM | |
Joined: 4/30/2010 Last visit: 9/28/2023 Posts: 119 Rating:
yes I use VMware, so the IO adapter will appear once the network driver is fixed? |
9/20/2016 10:42 AM | |
Joined: 7/9/2015 Last visit: 9/28/2023 Posts: 3542 Rating:
Hi, you can check the following FAQ called What should you watch out for when installing STEP 7 (TIA Portal) on a virtual machine?Here you will find settings for VM - Hope this helps, Regards, Towome |
If my post was useful, please rate me - thank you! |
9/27/2016 11:35 AM | |
Joined: 11/14/2008 Last visit: 8/29/2023 Posts: 504 Rating:
Check PRONETA as well I would say , also a great tool ! |
