6/7/2012 5:44 PM | |
Joined: 1/28/2009 Last visit: 6/5/2023 Posts: 6803 Rating:
Hello Sachin Patke, To find all you want,check chapter 25 ("Indirect Addressing") of "Automating with STEP 7 in STL and SCL" and these are samples you want:(STL BOOK->Variable Handling ->Blocks->FB125. Best regards, Hamid Hosseini |
7/9/2012 5:44 PM | |
Hello , Please see what I have done in the attachment. I have no problem and the new Library added to the list.I suggest you manually search the retrieved file in "S7LIBS" folder.The retrieved file may be copied inside a folder in "S7LIBS" Best regards Hamid Hosseini Attachmentlibrary.zip (51 Downloads) |
