6/19/2009 3:05 PM | |
Posts: 261 Rating:
At the time of installation you have to select your desire language. Regards ddg |
6/22/2009 4:16 AM | |
Posts: 35 Rating:
thanks ddg I have do the selection as your guide but it not works...others of step7 window are display in English, only the window for setting parameters for PtP displays in Deutsch...at the first time after installed software, it was in English, however, after about two months it change to Deutsch...I try some solution but nothing works ALU, ----------------------------------------------------------------------------------------------------------------------------------------- hi all, at last my problem has solved as follows: https://www.automation.siemens.com/tf/WW/en/Posts/27153 ALU, |
