4/12/2021 3:49 PM | |
Joined: 10/11/2006 Last visit: 2/3/2023 Posts: 5412 Rating:
Hello, yes it is possible. But resolution of the encoder should be 5-6 times higher than the required position accuracy. G120 is not isochronous, so you get worse control behavior. How can you realize the encoder configuration for the “positioning axis” technology object? https://support.industry.siemens.com/cs/ww/en/view/109486133 Or via DATA Block https://support.industry.siemens.com/cs/ww/en/view/109741575 |
With best regards, |
4/13/2021 8:14 AM | |
Joined: 9/23/2005 Last visit: 2/3/2023 Posts: 4088 Rating:
This link is something else. It leads to https://support.industry.siemens.com/cs/document/109741575/step-7-v5-x-hardware-support-packages-(hsps-as-at-01-2021)-for-installing-hardware-updates-in-the-hardware-configuration?dti=0&lc=en-WW |
Regards, |
