12/4/2020 2:21 PM | |
Joined: 10/11/2006 Last visit: 2/6/2023 Posts: 5417 Rating:
Hello, How can you realize the encoder configuration for the “positioning axis” technology object? https://support.industry.siemens.com/cs/ww/en/view/109486133 |
With best regards, |
12/10/2020 11:01 AM | |
Posts: 23 Rating:
Thanks for your response. Sadly I already consulted that documentation. I'll try to make things clearer. I posted a zip file with 2 screenshot, marked v2 and v4. In v2 you can see that i can easily select my encoder connection type, while in v4 is not possible. It's the same hardware configuration, same drive, same encoder, same plc and same network. Question is: Will it work anyway? AttachmentMotion.zip (79 Downloads) |
