7/21/2008 11:33 AM | |
Joined: 8/25/2005 Last visit: 7/5/2024 Posts: 1161 Rating: (110) |
Hello Rasmus7700, I have no experience with your application. But searching through the Techncial Forum, there are more threads about that I think. For example this one: USS and S7-300 in contrast to S7-200 Maybe it will be helpful? Best regards Sabine |
7/28/2008 3:24 PM | |
Joined: 9/29/2005 Last visit: 4/26/2022 Posts: 313 Rating: (24) |
Hi, maybe this application helps you to understand how to use USS protocol on s7-200 side. http://support.automation.siemens.com/WW/view/en/21690362 here you can order the most actual USS libraries (for both ports) https://mall.automation.siemens.com with this MLFB: 6ES7830-2BC00-0YX0 Detailled information regarding USS you find in the S7-200 manual http://support.automation.siemens.com/WW/view/en/1109582 from chapter 11 regards Lif |
8/22/2008 8:59 PM | |
Posts: 6 Rating: (0) |
Off course, that sounds like an idea i can use :) Thx Alot :) |
9/11/2008 2:35 PM | |||
Posts: 487 Rating: (45) |
Here is a module that can be used with USS in S7300 in an ET200S station
You can also take a look at the link below for positioning blocks https://mall.automation.siemens.com/DE/guest/index.asp?aktprim=0&lang=en&nodeID=10000702&foldersopen=-1385-2957-3036-3042-3043-1386-2063-1837-1868-1876-1387-2064-2094-2100-2103-&jumpto=2103 |
9/16/2008 11:31 AM | |
Joined: 8/31/2005 Last visit: 8/20/2024 Posts: 2198 Rating: (328)
For S7-200 ther are some nice positionioning function blocks. I do not know if they work with USS too, but I think so. Look here: http://support.automation.siemens.com/WW/view/en/21063595 If you deside to use a S7-300, you can use Easy Motion Control (6ES7864-0AA00-0YX0) for positioning. I avaible you soulduse PROFIBUS, it's much faster then USS, the positioning will be better. Examples for EMC you can find here: http://support.automation.siemens.com/WW/view/en/20208582/136000&cssw=4 |
