2/26/2013 3:08 PM | |
Joined: 10/10/2005 Last visit: 6/15/2023 Posts: 1909 Rating:
Hello, look in the online help under chappter: "Inserting placeholders for metadata". With best regards Cicero |
2/26/2013 6:06 PM | |
Joined: 1/28/2009 Last visit: 9/25/2023 Posts: 6822 Rating:
Hello, Solutions can be found for Some of the cases if you know the data type very goods: 1-For data type "STRING", the first and second byte contains data related to structure of whole data set.Check more information here: STRING 2-Checking length of global and instant data blocks, check more information here: L DBLG: Load the length of a global data block into accumulator 1 L DILG: Load the length of an instance data block into accumulator 1 For others, consult same manuals as I have used Best regards Hamid Hosseini |
