4/6/2011 6:30 AM | |
Posts: 13 Rating:
Hi! They are using knx automation network in home electronics. Is it possible to connect knx devices to S7-300 somehow? |
4/6/2011 7:06 AM | |
Joined: 3/21/2006 Last visit: 3/19/2025 Posts: 10239 Rating:
KNX/EIB2S7 Editor and Function Blocks for Commuication to KNX/EIB BUS over ETHERNET : version 1.0 |
4/6/2011 7:16 AM | |
Posts: 13 Rating:
Link wont work. There is correct link: https://support.automation.siemens.com/WW/llisapi.dll/46374645?func=ll&objId=46374645&objAction=csView&nodeid0=37840576&query=eib+s7&lang=en&siteid=cseus&aktprim=0&extranet=standard&viewreg=WW&load=treecontent&prodLstObjId=37988041 Will this work with S7-300 and CP343 (-1EX11-)? |
4/6/2011 7:25 AM | |
According to above mentioned link - no will not work. Best regards, Hristo Mihalev |
4/6/2011 7:34 AM | |
Posts: 13 Rating:
Thank you for reply. Is there some manual where I can see knx basic details and get to know how it works? |
6/1/2017 10:42 AM | |
hi simppa80, S7-1200 or S7-300 have no KNX-interface. KNX is used in building automation. The CPU´s are for industrial automation. So you need something that converts. I´m not sure if it help, but have a look here: KNX/EIB2S7 Editor and Function Blocks for Commuication to KNX/EIB BUS over ETHERNET : version 1.0 regards, |
FCK WAR! |
