3/6/2013 10:56 AM | |
Posts: 70 Rating:
(see Circuit.jpg) |
3/6/2013 4:48 PM | |
Joined: 10/11/2006 Last visit: 2/6/2023 Posts: 5417 Rating:
Hello, After checking your drawing these connections won´t work properly with a Sinamics S110 and a standard PM340 3AC 400V. You will find in the links belowsome more informations about using S120 / S110 AC/AC components. There are of course PM340 with 1phase AC 200...240V available. But if you are using a 3 phase 400V net you need also a 3 phase 400V main power net. http://support.automation.siemens.com/WW/view/en/68045304(S120 AC/AC Manual) http://support.automation.siemens.com/WW/view/en/49086218(Sinamics S110 Equipment Manual) |
With best regards, |
3/6/2013 5:51 PM | |
Posts: 70 Rating:
What is the difference? Thank you in advance for your answer |
