7/1/2009 7:22 AM | |
Posts: 160 Rating: (16) |
Yes this can be done with PS307 power supplies Please refer to the following link with regards to details about the Sitop Redundancy module https://www.automation.siemens.com/sitop/html_76/redundanzmodul.htm Here is also a link to the sitop catalog http://www.automation.siemens.com/infocenter/order_form.aspx?tab=3&nodekey=key_518431&lang=en I hope this helps |
7/1/2009 7:33 AM | |
Posts: 76 Rating: (8) |
HI, You may use the 6EP1961-3BA20, which is a redundancy unit with two SITOP power supply! Good luck! |
