6/9/2009 12:29 PM | |
Posts: 54 Rating:
Hi all, Now I am use WinCC 6.2 and WinCCAdd-on Powerrate 2.0, but when I use faceplate in WinCC, I try to connect faceplate tag to gets datafrom AS (S7 300 CPU 317) following the manual (as attachment file post with this thread), butit isnot display "Connect picture block to tag structure" any more in Standard Wizard. Is it onlysupport PCS7 OS? ( Note that icon PCS7 indicatorson picture ofmanual). Pls give me some advises to connect data between PLC and WinCC using faceplate in WinCC Add-onPowerrate 2.0for power managing. Thanks in advance, Nguyen Anh Tuan tuanna@ntc.com.vn AttachmentConfiguring a measuring point.pdf (314 Downloads) |
6/9/2009 3:49 PM | |
Joined: 11/21/2007 Last visit: 8/22/2023 Posts: 2321 Rating:
Hi Navnag |
There is no such thing as the last bug in a program |
