2/23/2021 3:04 PM | |
Joined: 8/3/2009 Last visit: 4/25/2025 Posts: 15355 Rating:
Hello Danie_Dktrl The Trend and Archive System of WInCC Comfort/Advanced has not beed changed the last few years. So you cannot change a Tag in a trend by VB Script or dynamize somehow. The only thing that comes in my mind is for Live trends, you could work with buffer bittriggered Trends (here a FAQ for flexible, but its the same in TIA: LINK) then you could copy the Values you want to see in the PLC from one DB to another For Archived Data its quite the same as you have already mentioned. You can try with Copy like in this Application: LINK For you amount of trends (500+) It would be also possible to think about a SCADA System with WinCC Professional. Here you can get work all your usecases. Bye Murof |
