4/15/2016 2:38 PM | |
Joined: 4/23/2010 Last visit: 11/23/2024 Posts: 8092 Rating:
Hello, I guess this is the same problem mentioned in this post. Please replace the resistance or rather any other component with technically equivalent/genuine spare or you may land in problem one or another day. Now to your problem, since your drive is of bigger capacity, I would recommend you to replace this spare from Siemens only, since pre-charging resistance is important & further more, try to find out the reason of failure of this resistance. HTH. |
