6/24/2009 9:36 PM | |
Joined: 1/4/2008 Last visit: 9/2/2024 Posts: 703 Rating: (96) |
Hello, the difference is obviously number of pins (20 or 40) and it's because of their usage. If you use for example 32 digital inputs module, you have to use 40-pin connector, when you use the 16 digital inputs module thenthe 20-pin connector is to be used. Look at the description of the modules you plan to use and order the connectors accordingly. Regards Sydney |
6/25/2009 11:30 AM | |
Posts: 1 Rating: (0) |
only the pin is different ,see the manual on the network |
6/25/2009 1:46 PM | |
Hello kinta, of course the shape is also doifferent, but the main thing is the number of pins and the usage for the different modules, I hope my first post was clear enough, if not so sorry for that. Regards Sydney |
