5/17/2007 1:30 PM | |
Posts: 1 Rating:
how can i present somerealtimedata (measurement) on web. i am using simatic WinCC V5.1. should I have to use any other component of wincc. |
5/17/2007 1:42 PM | |
Joined: 12/5/2005 Last visit: 10/20/2023 Posts: 239 Rating:
HI Coli, You can use the WinCC WebNavigator. See the page. https://mall.automation.siemens.com/WW/guest/index.asp?nodeID=10013018&lang=en It is necessary to verify the compatibility between your WinCC Version, the WinCC WebNavigator and OS that you're using. See the faq: http://support.automation.siemens.com/WW/view/en/21927668 |
Márcio Santos |
5/17/2007 2:11 PM | |
Posts: 1275 Rating:
Hi, If you had a newer WinCC version you could check out DataMonitor as well. In your case, WebNavigator is the way to go. As Marcio said, always check for software compatibility. In your case you'll use version 1.x of WebNavigator. Best regards, Danielle |
