3/22/2018 8:20 AM | |
Joined: 7/5/2013 Last visit: 4/17/2025 Posts: 3147 Rating:
Hello vinay, seems they found a solution here <print-datalog-csv-or-txt-file-for-comfort-panel>. Regards, Frink |
Pi is exactly three! |
3/22/2018 9:41 AM | |
Joined: 11/19/2016 Last visit: 4/4/2025 Posts: 38 Rating:
Hi, Thanks for your reply... I have tried this script but it doesn't work.. 😓 |
3/22/2018 10:50 AM | |
Did you follow all the "instructions" in the code that Jens posted at 10/15/2015 5:21 PM? - E.g. creating report Report_1 with alarm list linked to the SystemAlarmBuffer, setting PDF creator as standard printer in the panel, ... I guess you adapted directory, filename, .. to fit to your system. |
3/22/2018 12:13 PM | |
I have created report, csv file directory is also matched and my default printer is pdf creator.. though it is generating blank pdf document... Can you tell me what are other steps I need to do to use this script???? |
9/16/2020 1:10 PM | |
Joined: 5/8/2017 Last visit: 11/26/2024 Posts: 14 Rating:
Sir, Can you plase share your VB script I want to generate the report through VB script. |
