10/20/2011 4:19 PM | |
Posts: 68 Rating:
Hi, On my very first project I noticed that I was unable to print the project. TIA V11 Update 2 would crash or give an internal error when i tried to print the entire project. I thought my system had to less ram (2GB) and upgraded it to 4, no succes. (XP SP3) Later on I noticed that other projects printed just fine. It seems when u use a Cyclic interrupt OB you are unable to print this OB or the entire project. TIA wil give an internal error and/or crashes .... I have attached a little sample program.... When you right-click the Main OB and choose preview TIA generates the preview just fine. Right-click the Cyclic interrupt OB and tia will give an error or crashes. Same when you try this for the entire project .... Is there any workaround for this ? Greetings, Gunther. AttachmentPrint test.zip (146 Downloads) |
10/21/2011 8:15 PM | |
Posts: 68 Rating:
Did, you mean that you allready knew about this problem? I have searched the forum but did not found anything .... Thx for the workaround, i will try it ... |
