7/28/2006 3:20 PM | |
Joined: 10/19/2005 Last visit: 11/30/2020 Posts: 1611 Rating:
Hi, i think, it looks so that the OP do a restart! Did you check the connection between OP <--> PLC? Are you sure, that your "new" OP27 works well? Did you have a nother project which you can tranfer to the OP to check this? Did you have clear/initialize the storage medium? (I found this info in the manual for the OP => Chapter 9.2) http://support.automation.siemens.com/WW/view/de/1142800/0/en greeting, |
6/10/2008 2:25 PM | |
Joined: 5/8/2006 Last visit: 10/16/2024 Posts: 1085 Rating:
Hi, you can make an OS update with ProSave and after that you can try to again. Bye |
6/14/2008 6:52 PM | |
Joined: 5/13/2008 Last visit: 12/18/2019 Posts: 836 Rating:
Have a look in the manual, chapter 16.4. There you will find the communication options. http://support.automation.siemens.com/WW/view/en/1142800 |
mfG / Best regards |
