10/24/2018 2:32 PM | |
Posts: 1 Rating:
Hi All, Greeting for the day. I am facing problem in S 120 Drive with Cu 320-2 DP Every alternative day Drive is tripping with following fault codes. After power up again it continue working for next couple of days. Below of Fault codes P 30885 P1600 P30661 P30600 I checked with Drive Clique cable separating it from other power cables still problem is continued but with reduced frequency. Drive is connected to 2 motros without encoder . no other cables in Drive clique circuit please advise how can I check further. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 10/25/2018 9:42:09 AMNew subject after splitting |
10/25/2018 11:04 AM | |
Joined: 10/11/2006 Last visit: 1/27/2023 Posts: 5404 Rating:
Hello, I couldn`t find a fault number 30661, but the faults 1600 and 30600 are triggered due to the initial 30885.F30885 is usually caused by emc issues or lose/bad plug connections. If original Siemens drive-cliq-cables are used and emc could be excluded I would recommend contacting the customer support by creating a service request. https://support.industry.siemens.com/My/ww/en/requests#createRequest |
With best regards, |
7/6/2020 1:18 PM | |
Joined: 3/2/2007 Last visit: 1/9/2023 Posts: 818 Rating:
Kindly, how did you solve this problem ? |
... thank you ... |
