4/4/2017 1:44 PM | |
Joined: 8/3/2009 Last visit: 4/24/2025 Posts: 15350 Rating:
Hello ACDC24 look in this FAQ here should be your answer: https://support.industry.siemens.com/cs/ww/en/view/34230359 Its a WinCC flexible FAQ but you could go the same way in TIA Portal. Bye Murof |
4/5/2017 8:30 AM | |
Joined: 2/5/2011 Last visit: 4/6/2024 Posts: 90 Rating:
Thank you so much for your help. |
4/5/2017 8:31 AM | |
