8/3/2017 5:58 AM | |
Posts: 2 Rating:
Dear Expert I'm facing a problem regarding backups of Smart1000IE HMI. I have a backup taken via prosave of HMI 1000IE product ID6AV6648-0BE11-3AX0.But i need to restore that similar backup in 1000IE HMI with Product ID6AV6648-0CE11-3AX0. Can't get through the communication phase with PC. Quick reply will be appreciated. Thanks Regards Hamza Anwar ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 8/3/2017 8:24:29 AMNew subject after splitting |
8/8/2017 1:26 PM | |
Posts: 648 Rating:
Dear Hamza Anwar, your backup of panel 1 (6AV6648-0BE11-3AX0) isn't compatible with panel 2 (6AV6648-0CE11-3AX0). The article IDs are different. To solve this problem you have to change the device in your project configuration, make a recompile and download through your new panel. Otherwise you should contact the Technical Support of China. With best regards rh1990 |
