8/17/2006 3:36 PM | |
Posts: 3149 Rating:
Hi, why don`t you use SP4? Have you already checked the wincc logfiles for entries? nemo |
8/20/2006 1:21 PM | |
Posts: 102 Rating:
Or it may be your computer. Have you checked your OPC servers with another OPC client except WinCC in your machine? |
8/21/2006 12:44 PM | |
Posts: 19 Rating:
Hello Nemo, thank you for your response, does SP4 fix this? Is it a known problem? I checked log files,there´s several "AddItem", timeout errorserrors and messages like: "ERROR c0040007", "ERROR 80004005", and I found interest in this: "ActionOverflow:more than 5000 Actions to work" Attached the log files if you can take a look Any help will be appreciated, Regards AttachmentDiagnose 060821.zip (133 Downloads) |
8/21/2006 2:22 PM | |
Posts: 3149 Rating:
[quote user="Engelbert"]Hello Nemo, thank you for your response, does SP4 fix this? Is it a known problem? I checked log files,there´s several "AddItem", timeout errorserrors and messages like: "ERROR c0040007", "ERROR 80004005", and I found interest in this: "ActionOverflow:more than 5000 Actions to work" Attached the log files if you can take a look Any help will be appreciated, Regards Hi, first of all please correct your programming problems: 255,21.08.2006,11:57:45:906,1007001,4,,SCADA1,SCRIPT,ExecuteError in Action @23 => http://support.automation.siemens.com/WW/view/en/8385493 http://support.automation.siemens.com/WW/view/en/11965771 "ActionOverflow:more than 5000 Actions to work" => http://support.automation.siemens.com/WW/view/en/2357302 ERROR 80004005 => check your WinCC online help for Channel diagnose > Error flag http://support.automation.siemens.com/WW/view/en/16622456 => http://support.automation.siemens.com/WW/view/en/22091360 CHOOSE THE CORRECT FORMAT FOR YOUR TAGS: 255,20.08.2006,17:09:47:296,1000005,4,,SCADA1,DataManager Runtime,Format error of tag 'TRA_Tasa_tren_A.U'. Format ID: 136314880 = 8200000(hex) Well, this should be enough work for you at the moment [:D] => your Diagnose files must NOT contain error entries - then WinCC runs perfectly. nemo |
8/24/2006 11:16 AM | |
Posts: 3149 Rating:
Hi please searchWinCC online help for "action overflow" > "profile" > "APDIAG" there you can find some info (but not too much) [:cry:] nemo |
